Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Make blade knife from sketch
3 REPLIES 3
679 Views, 3 Replies
     I try to make a knife blade and i'm stuck when it come to make the edge. I try chamfer and loft but without any good result. I attached my file. Blade edge are define in the sketch. Any help would be appreciate.
Mike
3 REPLIES 3
etfrench
Use a sweep:
Notes:
Create an offset plane at the blade tip.
Create a sketch on the plane.
Project the blade body to the sketch.
Draw the desired edge profile.  I used a 3 point arc to simulate a hollow grind.
Create an offset plane (or midplane)  at the center of the blade.
Project the knife edge to the sketch (If you project the entire blade, delete all lines except for the edge lines).
Use a sweep to create the edge.
Mirror it to the other side.
ETFrench
ryan.bales
I generally use draft when i do mine. But if yours has that much curve then sweep is really the cleanest option.
Chamfer wont work because your lines do not create a tangent chain. The sketch curvature is rather jagged and any modeling will reflect that.
Ryan Bales
Fusion 360 Product Support
davebYYPCU
And Patch > Loft doesn't do a bad job,
do yourself a favour and scale the canvass. (its called Calibrate)
Technology Administrators
