Make assembly from Solidworks/ STEP import?
alandmarino
alandmarino
Hi, i have issues when import a full Solidworks assembly or STEP into Fusion. Geometry imports perfectly, next step i create components from bodies, but after adding joints nothing moves. As-built joint button is not visible either. Any suggestions? Sorry but didn't find the subject in the forum.
Thank you!
Alan.
PD: sorry for my english, not native.
jeff_strater
Hi Alan,
This should work.  Can you post the STEP file, so we can investigate it?  Thanks,
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
alandmarino
File uploaded!
Thanks!
Alan.
jeff_strater
Thanks!
So, a couple of things here:
1. the STEP file already contains components, so  you don't need "create components from bodies":
Then, adding joints:  First, the reason why As Built Joint is not available is because this design is a Direct Modeling design.  To get As Built Joint, you need to convert to a history-based design:
You don't need to use as-built, but in this case it's easier, I agree.  So, convert to history, then use as-built joints.
Jeff
Jeff Strater
alandmarino
Thank you very, very much! specially for the incredible fast feedback!!!
Alan.
