Make Assembly Component into Separate File
I have an assembly of components that I would like to break out into individual single body files.  How do you do that?  I plan to rebuild an assembly now that we have file assosciations available so I can work on an individual component outside of the master assembly.
TrippyLighting
Highlight the component or assembly right-click on it and save-as.
If you've applied the correct workflow then the new saved file will contain the timeline that pertais to that assembly and its components.
I promise you, I clicked on everything I could trying to find that functionality. I must have been sleeping or something.
Thank you for your help. Works perfectly.
ManikantaAthukuri
Works perfectly.Thanks
Manikanta Athukuri
