Im trying to make a mold in this cylinder, I started with the smaller hole in the center but I don't know how to make only half of my drawing clear so I can see only half of the cylinder and work with the inside along the axis.
Solved by jhackney1972. Go to Solution.
While in a model, you can use Sectional Analysis to slice a model using any plane. While in a model sketch you can used Slice to slice the model to the sketch plane.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
