Machine multiples in sheet
snoofydog
snoofydog
Hi Guys,
I wish to machine  9 x multiples of this surface 25mm deep into a sheet.
I am struggling with the split body command, as it doesn't want to pick the whole bowl, only individual surfaces.
I can't seem to combine the bowl as a whole
Would I then pattern the bowl x 9 and machine or toolpath one and pattern after?
etfrench
I'd use a pattern in CAM, but model the bowl differently. See attached file.  I just used one 3d toolpath to show the technique. You'll want to use other toolpaths to create the finished bowls.
ETFrench
