Announcements
Mac Tree Option Don't work
bmxjeff
bmxjeff
hey,
So, It must be a known error, because it's been around awhile, and I reported aspects of it before.
When I start Fusion in Model mode, all is well. But, after I switch to CAM and then come back to model, I can't change the Units or activate a Component.
Also, when I go into CAM, I can't activate a Setup.
This is everyday, every model. If I switch to SIM, then to Model, it might start working again.
Thanks!
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
macmanpb
@bmxjeff Here too.
I am also a mac user. 😉 I found out, if you click the fusion window top bar the browser might work properly again. But it is very frustrating...
bmxjeff
That's a better work-around. Thanks!
Jeff Hooper (Owner)
bmxjeff
Since this is a bug, is this logged? or anything?
@BryceHeven I will report this one to Bryce! Straight to the top! Because you know it's there! haha
Jeff Hooper (Owner)
BryceHeven
@bmxjeff I have definitely seen this behaviour. My trick is either to resizethe window or click the top bar. I also do this slow click and drag over to select the set up.
What i mean is:
Click the setup
Hold mouse down
drag slowly to where the radio button should be
it pops up about 80% of the time.
I will check if it's logged.
Bryce Heventhal
Sr. Mgr. Technical Marketing, Design & Manufacturing
Link Name | Link Name | Link Name | Link Name
