losing parametric ability by change of parameter
conjured2018
conjured2018
attached is a design of a box. box has dovetails. at this point if I change any parameter the  back right side feature is lost . for clarity the longer body is the back.
I did change side body or first body to component after i designed it having forgot rule 1.
thank you, JR
jhackney1972
I hope I understand what your problem.  Check out the attached assembly to see if your problem is taken care of.  If so, note I changed the Mirror from Adjust to Optimized.
John Hackney, Retired
conjured2018
thank you, JR
