Looking for workflow advice – to sweep or not to sweep?
I'm blocked on the best way to approach modelling this part. I've tried various approaches including sweeping, lofting and patching with little to no luck.
I'm hoping someone can point me in the right direction of the best workflow for the task.
Ultimately I am looking to sweep the closed triangular-ish profile along the bottom rail seen below. It's very simple along the straight section obviously, but I keep running into errors as it attempts to complete the shape at the end of the rail. Would I be better off removing the fillets on the profile and the end of the rail and just adding those in by filleting the solid after the form has been created?
I have also attached the fusion file for the sketch curves shown above. Any guidance would be much appreciated! Thank you all.
