Looking for guidance on creating movement in an Assembly
I'm attempting to create movement between a bolt attached to an outer sleeve along an inner sleeve groove. I'm having trouble deciding which is the best or even a valid method of how to create the desired result. Cylindrical joint movement seems to make the most sense, but defining limits hasn't been as easy to grasp. The outer sleeve, handles, and bolt are a rigid group as to move together. I've set joint origins as the beginning and end of the grove in an attempt to limit the path. Any help would be greatly appreciated.
I can supply the file if needed to aid in the instruction or understanding of the model. If i'm not being descriptive enough, please let me know and I'll gladly elaborate where needed.
I figured it out!!! Creating a cylindrical joint between the base of the bolt and the inner sleeve, then establishing a motion link with a set limit of 3 inches (distance of the coil) allowed me to create the rotating movement I was seeking. If anyone has this specific problem in the future I hope this helps.
davebYYPCU
Presuming the sleeve is grounded, Cylindrical joint, on the axis of the barrels,
You want the Revolve Joint limit to be one turn, (360) on the revolve,
the X limit on the distance.
File will help with more specifics.
Thank you for the concise explanation!
