Looking for advice for how to model a surface
rodfrey
rodfrey
Sorry, title is very undescriptive - part of my problem is I don't even know what to search for!!
I'm modelling a pair of sunglasses, and I'd like to take a scoop out of the back to thin out the frame along the lens.  In the snip below, I'd like to scoop out something like the (crude!!) red line shows.
I can't figure out a good method to do this!  I've tried drawing two curves in front and back, and lofting a cut between them, but I don't get the shape I want nor the control I need. Ideally I'd like to sketch right on the curved inner and outer surfaces of the frame and cut between them, but I can't figure out how.
Is this a Patch environment thing? Is it a 3D sketching thing?  Is there an even better way I haven't thought of?
Thanks!
Lex_Story
I would build a cutting tool shape and use a bool operation. The cutter and exceed the volume of your target shape.
Cheers,
Lex
TrippyLighting
I’d use a surface loft in the patch environment of achieve smooth curvature. Can you export your design as a .f3d file and attach it to your next post ? I can show in a screencast how to do that.
there are several ways to do that,  and using a combine-cut operation with another solid body would also work. It really depends on what geometry you’re after.
rodfrey
Thanks, both of you. I managed to do what I wanted by figuring out 3d sketching and running a rectangular cut area along a spline that more-or-less followed the frame outline.
I'd export my model, Peter, but Fusion won't let me - I had some externally referenced components in the design and Fusion 360 says export to .f3d isn't supported. Even though I've deleted the external components, that flag is still set and I still get the message.
TrippyLighting
There are other methods to share a design.
Find your design in the data panel right click on it and select "share public link". Make sure to enable download. Then post the link here.
rodfrey
Thanks for that!  http://a360.co/2zT8V05 is the link.
