Look at Face (bug?)
Look at Face (bug?)
neljoshua
Advisor Advisor
Look at Face (bug?)
neljoshua
So, I do not know if this is a bug or not.  If it is not, perhaps someone could explain it to me.
Say that I open a model and use the ViewCube to look at a face (by clicking on Front, Right, etc).  Before the model is moved around (and the orbit point is changed) this results in behavior I expect; I am allowed to look at the face I want to.
If, however, the user selects a different orbit point (something other than COM) and then orbits a bit, this method seems to get out of whack.  Clicking on a face of the ViewCube results in erratic behavior such as panning the model so that none of it is visible in the window and zooming to some arbitrary level.
I thought that perhaps that this had something to do with the orbit point, so I changed it a few times.  This, however, does not seem to help things, as Fusion is not using the orbit point for the center of the screen when using this method.
I was able to reproduce this with a simple model of a box, although it is much easier to do with a larger model.  I started the Screencast with a "home" operation so that you could see there are no entities (components or otherwise) hiding somewhere on the fringe of the model.
Does anyone know why this is happening?  It is super frustrating when I am zoomed in on a small detail of the model to take measurements or change geometry, attempt to look at a face with the ViewCube, and the entire model zooms and flies off screen.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
JDMather
It might be worth the effort to create some Named Views.
Have you tried using the Constrained Orbit option? (to the left of LOOK AT tool)
This seems to keep geometry centered in the view.
neljoshua
@JDMather & @Anonymous,
Thanks for the suggestions.
__
