Lead Screw Motion
Lead Screw Motion
Lead Screw Motion
Hey how's it going, is there a particular method for accomplishing this type of motion? As soon as I constrain one of the silver guide posts I am unable to rotate the "lead screw" in this case. Could I configure this to allow linear motion via the rotation of the threaded rod and movement along the posts? Thank you in advance. I've created a motion link between the two in accordance to another Fusion 360 guide (the example used a vice).
Can you export and save a copy of the file here as an attachment?
Apologies for the tardiness, here is the requested file.
O.Tan
I'm guessing you want the motion where when the lead screw rotates, the block moves up and down and it's guided by the 2 rods to prevent twisting?
You're probably looking at rotational/cylindrical joint for the lead screw and slider joint for the block and rod. Then use motion link to link both joints so when you rotate the lead screw, it'll have the rotational movement and translating your block along the z-axis.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
I made two cylindrical joints for the posts and a revolute joint where the thread meets the lead screw and a motion link between the two revolute joints (bottom and at the block).
It seems I was joining it together in the wrong sequence, when applying the cylindrical joints first and then the revolute it produced the desired result. Thanks O.Tan!
