Lofting problem
Lofting problem
borisdimitrov.md
Message 1 of 9
Lofting problem
borisdimitrov.md
Hello, I need to loft these surfaces, but I cant. Please help 😄
Replies (8)
Message 2 of 9
TrippyLighting
Good luck!
You might find Autodesk Meshmixer is a better application to work with triangulated meshes.
Also, it usually helps if you can share the model in some form.
Message 3 of 9
borisdimitrov.md
Sorry it is my first day with Fusion360 here is screencast.
https://a360.co/32kaRte
Message 4 of 9
TrippyLighting
If this is your first day with Fusion 360 you should by all means go through the tutorials in the Learn & Support section of this Forum. Afterwards you'l have questions but you will be much better equipped to ask questions.
Fusion 360 is a CAD program and .stl files are NOT CAD geometry. As such you'll have an uphill battle on your hand if you continue.
Message 5 of 9
TheCADWhisperer
Are you a student?
Message 6 of 9
borisdimitrov.md
I am not a student, I am MD, but this is my first time with Fusion360.
I need to learn how to modeling medical implants from CT scan. A 2D model is showed in attached pic.
So
1. I convert DICOM files /images from CT or MRI/  to .stl
2. Convert Mesh to BRep
3 Slice two cylindrical parts from bone with radius of bone saw.
4. Rearrange them in correct way.
5. Merge some facets to a single profile.
6.!! now I need to loft these surfaces but "Warning: Could not approximate the notional curve for a boundary geometry"
7 when I get this body I plan to add some support material and screw holes.Screen Shot 2019-08-07 at 9.32.34 AM.png
I learn how to work with program in the same time.
If you can give me advice how to do it in fusion or which program to use it will be a great help
Message 7 of 9
TrippyLighting
Please zip and attach the .stl file. I can show you a method how to do this!
However, still, go through the tutorials as the will provide a basis for continuing work in Fusion 360.
Message 8 of 9
borisdimitrov.md
Thank you very much. These files are .stl and .f3d after cutting cylindrical shapes and one .obj file before cutting procedure.
Best regards!
Message 9 of 9
TrippyLighting
One approach would be to re-mesh the scan from a triangulated mesh into a quad mesh. That you can use in Fusion 360 and convert it into a T-Spline and then into a solid body, or BRep
See if this tutorial makes sense to you:
