Lofting - problem with rails
Hrvoje-
Hrvoje-
When lofting I have the problem to select the rail. How to select exactly the rail I need?
The file is attached.
I can't close the hull properly.I can't close the hull properly.
Kind regards,
Hrvoje 🙂
Marco.Takx
Hi @Hrvoje-,
Within the Nacrt you have to break 2 lines.
This cost the rail problem.
Attachment the new file version
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Hrvoje-
Thank you, Marco!
Can I somehow integrate two lines into one (line + spline)?
Kind regards,
Hrvoje 🙂
Marco.Takx
Hi @Hrvoje-,
No that isn't possible, but for rails, you can continue clicking until you reach the end you want.
Marco Takx
