Lofting Points
Lofting Points
Lofting Points
I am attempting to do a Loft and I am getting this error Message.  "All profiles are point profiles.  A loft needs
at least one non-point profile."  What is going on?
TrippyLighting
Isn't that obvious ?
You cannot loft between points. You can loft between a point and a curve or between curves.
You want to provide more detail and maybe share your model so we can get a better understanding of what you want to do.
chrisplyler
Logically speaking, lofting only from one point to another would create a one-dimensional line.
But nobody thought to include code within Fusion to output a line when you perform such a loft, because it is intended to result in at least a two-dimensional body, and because the intended workflow for producing a line is to...you know...sketch a line.
