We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Lofting - Getting one section to follow a sketch (Help)
thomas-buchan
Message 1 of 10
thomas-buchan
Hello
I am designing a duct for my car i am building, i have been teaching myself how to use the loft feature by watching videos and reading but one thing i'm having trouble with is getting a section of the loft to follow a sketch (Not center line).
Using the Direction function has got me 90% there but the long section needs to be changed so it doesn't tapper off into a point.
If you look at the model and picture, i'd like the back long section (From the middle point) to follow the curve drawn in the Z plane and i'm not sure how to do this.
Any help is appreciated (all open tolerances if you have to change anything as this is just a prototype and a chance to learn)
Replies (9)
Message 2 of 10
TheCADWhisperer
Sketch1 is missing many Tangent Constraints and also missing dimensions.
I would model using obvious symmetry about the Origin.
Sketch2 location is not defined?
Sketch4 is not connected to Sketch 1 and 2?
(I would probably create Sketch4 geometry before all other sketch geometry.
Message 3 of 10
g-andresen
First, sketch 4, which is intended as a guide rail, must be placed in front of the loft in the timeline and positioned (sketch plane) so that the curve can be connected to the two profiles.
günther
Message 4 of 10
TheCADWhisperer
I hesitate to mention this - but I might use a Spline for the one closed profile, but most users attempt to use wayyy too many points in their spline.
Message 5 of 10
g-andresen
Here is a construction with a mirrored loft for the base profile.
Watch the screencast and follow the development in the timeline.
günther
Message 6 of 10
thomas-buchan
Thank you for taking the time to make a video, seeing it really helps, it taught me some other unrelated handy things as well.
Message 7 of 10
thomas-buchan
Any tips for the error "Rail is not smooth"
It's a Tangant arc going into another tangents arc so i wouldn't of thought that wouldn't of been a problem with the both being curves.
Message 8 of 10
laughingcreek
Not enough info to go on. can you attach a file?  The rail not smooth error shows up for other errors also, so it's not always clear.
FYI-once you add a rail, direction condition on a profile no longer has any influence.   I would consider that a bug.  conversation I had with AD a while back seemed to indicate that AD thinks that's the way it should function.  If you need a tangent condition along that profile, you'll have to pull a helper surface off it and use the edge of the surface
Message 9 of 10
thomas-buchan
Hi, Thank you for getting back to me
I've attached the new model and i will just use "connected" instead of direction when using rails as suggested from now on.
Message 10 of 10
g-andresen
The problem is caused less by the rails than by the quality of sketch 1.
I had already recommended using a spline in an earlier screencast. But it also works with tangential conditions and partial replacement of curves by splines.
Have a look at the screencast and the file.
günther
