Lofting error "rails do not intersect all profiles" but says its coincident
gd0g4277
Message 1 of 11
gd0g4277
First off i've only been using fusion for about a week so im pretty green.  I'm trying to create a loft with 2 profiles and 4 rails.  I successfully created a loft with 3 profiles but keep getting error "rails do not intersect all profiles.  I 3d projected my sketch and im trying to make a rail from the purple line to another rail.  It looks like its snapping to the profile just fine and says its coincident but if I zoom in its a few thousands off.  What am I doing wrong?
Replies (10)
Message 2 of 11
wmhazzard
Sketch your rails last and use the intersect tool in the sketch environment to get the rail to intersect your profiles. If you sill can't figure it out, attach an f3d file of your model.
Message 3 of 11
gd0g4277
Thank you for the response.  I tried with the intersect tool and still got the error.  Here is the file.  This is only my third ever model and first in fusion so hopefully its not too much of a mess lol.
Message 4 of 11
davebYYPCU
The error is correct.
Your last Loft has 2 profiles,
all - ALL four rails must connect to both profiles, you have Rail 4 connected to Rail 1.
You can’t do that.
Might help......
Message 5 of 11
gd0g4277
This helped a lot.  I didn't fully understand how the profile and rails worked until you just said that and it clicked.  Thanks Dave
Message 6 of 11
gd0g4277
Ok now that I have that fixed i've ran into another issue.  It wont let me thicken.  I keep getting this error. (Pic attached)
Message 7 of 11
TrippyLighting
We need to see the current model.
1. How much do you want to thicken it?
2. Does that create self intersecting geometry due to too small radii?
This is not an object I would design with lofts, I'd use T-Splines.
Message 8 of 11
gd0g4277
Wanting to thicken .09375 inches (3/32). I lofted a t spline with the same result. The reason I’m lofting this is because there’s a certain bottom curvature in this model that needs to be exact for this part to fit correctly(I’m pretty ignorant on t splines as I’ve never really used the feature yet).  If I unstitch and try to thicken separately, it lets me thicken the back smaller section but not the front. I will upload the file when I get off work. Thank you for your time
Message 9 of 11
gd0g4277
Here's the file for it.
Message 10 of 11
TrippyLighting
I created a section cut and sketched a circle with the thickness you specified as the diameter. As can be seen, the circle  does not fit in that small crevice. This is an indication  that when offsetting, thickening or shelling it would create self intersection surfaces, which Fusion 360 does not permit for good reasons.
You also are lofting into two singularities (circled in red).
Message 11 of 11
gd0g4277
Thanks Peter.  Looks like I will need to smooth my loft more then?  Also on the singularity's, this is only half of the model.  I planned on mirroring it to create the full model.  Is that not possible with this geometry?
