Lofting error "rails do not intersect all profiles" but says its coincident
gd0g4277
1,093 조회수
10 답변
1/11 메시지
gd0g4277
First off i've only been using fusion for about a week so im pretty green.  I'm trying to create a loft with 2 profiles and 4 rails.  I successfully created a loft with 3 profiles but keep getting error "rails do not intersect all profiles.  I 3d projected my sketch and im trying to make a rail from the purple line to another rail.  It looks like its snapping to the profile just fine and says its coincident but if I zoom in its a few thousands off.  What am I doing wrong?
수락된 솔루션(1)
1,094 조회수
10 답변
답변 (10)
2/11 메시지
wmhazzard
Sketch your rails last and use the intersect tool in the sketch environment to get the rail to intersect your profiles. If you sill can't figure it out, attach an f3d file of your model.
3/11 메시지
gd0g4277
Thank you for the response.  I tried with the intersect tool and still got the error.  Here is the file.  This is only my third ever model and first in fusion so hopefully its not too much of a mess lol.
4/11 메시지
davebYYPCU
수락된 솔루션
The error is correct.
Your last Loft has 2 profiles,
all - ALL four rails must connect to both profiles, you have Rail 4 connected to Rail 1.
You can’t do that.
Might help......
5/11 메시지
gd0g4277
This helped a lot.  I didn't fully understand how the profile and rails worked until you just said that and it clicked.  Thanks Dave
6/11 메시지
gd0g4277
Ok now that I have that fixed i've ran into another issue.  It wont let me thicken.  I keep getting this error. (Pic attached)
7/11 메시지
TrippyLighting
We need to see the current model.
1. How much do you want to thicken it?
2. Does that create self intersecting geometry due to too small radii?
This is not an object I would design with lofts, I'd use T-Splines.
8/11 메시지
gd0g4277
Wanting to thicken .09375 inches (3/32). I lofted a t spline with the same result. The reason I’m lofting this is because there’s a certain bottom curvature in this model that needs to be exact for this part to fit correctly(I’m pretty ignorant on t splines as I’ve never really used the feature yet).  If I unstitch and try to thicken separately, it lets me thicken the back smaller section but not the front. I will upload the file when I get off work. Thank you for your time
9/11 메시지
gd0g4277
Here's the file for it.
10/11 메시지
TrippyLighting
I created a section cut and sketched a circle with the thickness you specified as the diameter. As can be seen, the circle  does not fit in that small crevice. This is an indication  that when offsetting, thickening or shelling it would create self intersection surfaces, which Fusion 360 does not permit for good reasons.
You also are lofting into two singularities (circled in red).
11/11 메시지
gd0g4277
Thanks Peter.  Looks like I will need to smooth my loft more then?  Also on the singularity's, this is only half of the model.  I planned on mirroring it to create the full model.  Is that not possible with this geometry?
