Lofting and rail error.
Matt1G
Message 1 of 14
Matt1G
Brand new to fusion 360. Im trying to model this small camera for a drone and cant figure out how to loft the edges of these arched rails on the sides of the body to the top circle area? I basically want the all of the top edges to loft to the bottom of the circle above. Is this even possible? I keep getting the following error... "the selected rail does not touch all the profiles. Any tips?
Replies (13)
Message 2 of 14
Haad_Ali
Kindly share your 3fd. file link.
Message 3 of 14
mango.freund
take a look. gr mango
Message 4 of 14
davebYYPCU
Yes it can be done,
Loft rail errors come from white dots in sketches, that are undefined.
Might help....
Message 5 of 14
TheCADWhisperer
Maybe something like the Attached (you should ALWAYS attach your actual file here)?
Keep Design for Manufacturability in mind when designing.
Loft is expensive, Revolve is cheap.
If you need Loft, you need Loft, just keep in mind that increases cost.
Message 6 of 14
Matt1G
Yes, this is exactly what I'm looking for but I cannot seem to get it to work properly. I'm sure its some procedural error on my part but I'm at a loss. Attached is a similar example I made at the point where I get stuck.
Message 7 of 14
TheCADWhisperer
@Matt1G wrote:
Yes, this is exactly ...
Did you open my file or did you just look at the pretty picture?
Message 8 of 14
TrippyLighting
Perhaps download the model @TheCADWhisperer had attached to is post and inspect what he did ?
Message 9 of 14
Matt1G
Yes, I understand your solution and I got it to work your way but can I also do it in the way I was trying originally with the loft function and just lofting it along the top edges and to the bottom of the circle? Thanks for the help.
Message 10 of 14
davebYYPCU
I didn't save my file, however the horizontal box fillet, makes the loft hard enough, but also leaves a crease on the red lines, due to the sharp corner change of direction.
Whisperer's simpler version has no crease, in these areas.
Might help....
Message 11 of 14
TheCADWhisperer
@Matt1G wrote:
...with the loft function and just lofting ...
Loft is a different (more expensive) solution of more complex geometry.
Do you need Loft because my "solution" is not in fact what you want?
Message 12 of 14
TrippyLighting
Yes, you probably can, but that doesn't make it a good idea. The quality of the surface will be terrible and difficult to manufacture with traditional (CAM) methods.
Even of you 3D print it and surface complexity is mostly free, you will likely see undesirable surface artifacts because, again, the surface will be terrible.
Message 13 of 14
TheCADWhisperer
I'll go into a bit more detail.
In some cases a Loft will create primitive planar, cylindrical, or conical faces - but in most cases Loft is more of "freeform" tool.  Think art sculpture.  It takes a particular skill to create aesthetically pleasing art sculpture.  Most people do not have that skill.  And those that do have often spent years developing that skill.  Those that don't create rubbish when attempting to create sculpture.  (It might look sort of good from a distance, but when you get up closer you see the flaws.)  Think of an autobody paint job where the bondo edges show through the paint.  Bottom line - get 6mths to 6yrs experience under your belt before attempting Loft.
If you are observant - you should notice that these corners in my "solution" are completely different your setup...
My "solution" droops down here (that is a artsy term). Ahhh, where are the emojis...
Message 14 of 14
TrippyLighting
Yep, all the while creating a lot of rubbish in the process of tying to get there 😉
