We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Lofting a mesh?
Lofting a mesh?
larryramaeker
Message 1 of 8
Lofting a mesh?
larryramaeker
So I took two models from a 3D print website, imported into the same document, set them together how I wanted them, but I cant figure out how to loft the gap between the two, to make it stronger.  I converted them both to a mesh, but I still cant figure out how to close the gap.  I tried sketching the same circle profile on the mount, but when I extrude to the base it encroaches on the inside because it is a chamfered square.
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
Can you sketch the expected effect?
Kacper Suchomski
Message 3 of 8
wersy
You can combine the two parts.
Message 4 of 8
wersy
Or do you mean like this?
just revolve a sketch
Message 5 of 8
larryramaeker
Yes, but I'm trying to add material to the joint between the parts.  Sorry I dont have the vocabulary to more accurately describe, see screenshot.  The green is what I'm trying to do.
Message 6 of 8
larryramaeker
The green is what I'm trying to accomplish.  Add material to the weak joint/high stress area.
Message 7 of 8
wersy
You only have to modify the sketch for revolve
Message 8 of 8
larryramaeker
Awesome, that makes sense, thank you!
