lofting 3 curves issue with rails
C.H.H.
C.H.H.
Trying to loft between 3 curves/cut faces, have tried surface and solid, same issue. File attached. Thanks in advance.
davebYYPCU
Using Loft would be 2 profiles and a Rail, but it self intersects.
so 20 at once can be done with the Sphere.
Might help.....
jhackney1972
Take a look a the method I used in the attached Screencast.  At the end, I Removed the extra bodies one at a time but you can do them all at once if you desire.  Model is attached.
Edit: If you want to, you can Combine the Plug and your three half spheres is you desire.  Make sure you turn off Keep Tools in the Combine dialog.
John Hackney, Retired
C.H.H.
Brilliant, learned something new. Thank you for taking the time @jhackney1972 and @davebYYPCU
