Lofted and other objects cannot be combined.
jeonghueil
Observer Observer
jeonghueil
Observer
Observer
I made the bodies, and I made the Loft that connects the bodies.
But there's a problem that's irregularly, and it doesn't merge very little.
This is a problem that I always experience whenever I work on it.
The problem is "irregular" and each body is physically clear, so I don't know if it's a program bug or what I'm doing wrong.
The problematic part is the part of the body folder in the file that is in the "T" folder.20221017_100947.png20221017_101011.png
please help me
etfrench
It appears the piping structure is symmetrical, so just mirror the right side.  You may need to use the split body command to separate the pipe structure from the base.
ETFrench
Bunga777
The body operation may not work well if the faces are in contact with each other.
Therefore, we expect that moving the faces so that they slightly overlap will make it possible to composite them.
It seems that there is a problem with the composition of the faces in this area, since the synthesis succeeds when this area is removed.
It seems that if I re-create only this column part in the loft, I can composite it correctly.
I am pretty sure that the shape of this part has an unfavorable shape for synthesis.
If it is possible to re-loft this part, then it would be an easy solution to work around it.
