Loft with rails from two splines - errors
and.magro
and.magro
I'm trying to generate a loft using 2 profiles and 2 rails with splines, but what initially seemed a simple design now is driving me crazy.
When I tried to loft the profiles with the guide rails I got some errors, and I already tried everything to solve those problems but with no luck.
The picture bellow shows what I want to do. Fusion360 Proj: http://a360.co/2nu9LLG
After seeing some videos I tried to replicate the simple example presented in one of your youtube videos, but again with no luck.
Here's the Fusion360 project of this last example: http://a360.co/2oeN5he
What could be wrong?
cad3na
Rail 1 and Rail 2 seem like start and end in Profile 1 and just pass Profile 2. Is this the case?
and.magro
Yes, It's the case, like the F360 youtube video.
cad3na
In the video it's shown with 4 rails (4 lines following the path up to the point) for the tent, even if they look as 2 lines, they are four.
https://youtu.be/fXQ28AVaMh0?t=11m21s
Perhaps if you break the lines in the sketches to separate at the profile 2
and.magro
Thanks for that tip, problem solved! 😉
