Loft with curved edge ?
Hi, Is there a way to loft between two planes, with a curved edge instead of a straight edge ?
Thank you.
 Basically like this:
lichtzeichenanlage
You can defines rails to model the faces. Perhaps this tutorial helps you:
lichtzeichenanlage
Can you watch screencasts
laughingcreek
we'll, same answer here. Rails. Already did a simple screen cast so I'll go ahead and post it.
You can also get some curvature by adjusting curvature settings on profiles. (did that some at the end)
Brady_Fulton
Loft followed by a sweep may achieve your desired result.
