Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to taper the top of this rib. Using the loft I tried cutting the corner off. I need to taper it while following along the curve of the face. It leaves part of the face uncut, not sure how to fix it. Also if i select the outer edge as path I get message it is not smooth?
