My last loft appears to be twisting the edges, I am not sure how to remedy. I believe it is just how the edges are identified/ numbered, but how do I fix this. Screen Shot is the "twist"
Solved by etfrench. Go to Solution.
Have you tried Surface workspace lofts? You may need to add more rails to get all four sides correct.
ETFrench
Essentially, you added a rail at each change in vertices? I havent tried this, I'll give it a shot.
Actually you don't need any more sketch rails. Start by surface lofting the two sides. Use the edges of those as rails for the top and bottom lofts.
ETFrench
I tried, either the loft would still rotate, or connection rails weren't intersecting the surface to loft. I tried to change the design slightly, but still I can not get what you described to work. The last pic is a screen shot of where I am at
