Loft Problem
Loft Problem
moh2063
Message 1 of 9
Loft Problem
moh2063
Hello everyone,
I need some help, I'm not very good at 3D modeling. I'm trying to make a sort of katana blade, I drew the two faces, the shape, then I wanted to connect them with a loft, but I'm getting weird shapes.
Thanks in advance.
Replies (8)
Message 2 of 9
moh2063
Here are the other Screenshots.
Message 3 of 9
g-andresen
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 4 of 9
moh2063
Here you go.
Thanks in advance.
Message 5 of 9
Haad_Ali
I have to use the centerline for giving the direction of loft from bottom reference line and use extrude cut to remove body exceed the above reference line. Let me know if this helps. Or you want some different body. Thanks!
Message 6 of 9
moh2063
Thanks a lot, it's a pretty good idea.
I tinckered a little and used Surface Loft instead, it gave a very good shape.
Message 7 of 9
shahriarsifat1802164
In this case, I will prefer making a surface and then cut it into the required sape>>offset the surface up to 0.00 mm >> then thicken it>> and lastly hide the mane surface.
If fillet or chamfer is needed to add you can add them
If you have any further query feel free to post.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 8 of 9
or you can trim the surface and thicken it.
Thank you.
RUET
Thank you.
Message 9 of 9
I am providing a screencast, therefore.
RUET
Thank you.
