Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Loft problem/error
3 REPLIES 3
365 Views, 3 Replies
Loft problem/error
0502880
Hello!
I tried to do a quite basic ring shape with two different shaped/sized profiles. Didn't manage to do it, got an error message about profiles. Any suggestions how to do it? Shared link: http://a360.co/23SDLNr
Any news, when loft will work properly/better?
Loft problem/error
Hello!
3 REPLIES 3
jeff_strater
in reply to: 0502880
jeff_strater
This loft is definitely possible.  I would recommend choosing the outer circle as a "centerline rail"
I recorded a screencast, will post it when available.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Jeff Strater
jeff_strater
in reply to: jeff_strater
jeff_strater
OK, here is the screencast:
Jeff
Jeff Strater
Jeff
Jeff Strater
TMC.Engineering
TMC.Engineering
Try adding a second loft rail.  This can also be done with 2 sketches not 4.
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Timm
Engineer, Maker
