Loft issues/bugs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Still on my self-learning process of Fusion and recently have encountered several issues with the loft command that have been driving me nuts. While some issues clearly seem a bug, not sure about the others and that's why I am posting here for some help to clear up my frustration.
Attached is the f3d file with the basic sketch design and only 2 out of the 6 mov files I have made, which title correspond to the points below.
!! How can I send the other 4 mov files taking into account the limit of number and/or size of files to attach?
1. While on loft command (either new or edit) having the default guideline (even after changing its points position), when clicking on the cube it disappears, though it is still there and active as seen by the cursor icon and by clicking on it. Need to close and open Fusion to get it back again. [Not shown: It does not happen if the default guideline is changed to any other user defined guideline (rail or centreline) before using the cube.]
2. On a default guideline, which points position have been changed, after checking on Analysis tab different analysis types and leave None at the end, the default guideline goes back to its original position/points. When clicking in OK button still in Analysis tab, that change is taken into the design [Not shown 1: …but not if OK is clicked in Feature tab]. [Not shown 2: It reverts even in Edit Feature if same is done as mentioned]
3. Editing a loft feature (not new loft) with centreline, it shows Tangent Edges after going to Analysis tab and back to Feature tab.
4. To test 2 different rails have created two different lines on a sketch that go between the same points. On loft command, choosing any of those lines as a rail, for some reason it selects a closed profile and gives an error with that message. However, if 3 lines are created in the sketch between the same points, there is no problem and any of the 3 lines can be selected as a rail. [Not shown: Also, even having already one spline on one side and mirroring to that same side two additional splines (total 3 splines) the same issue appears but if mirroring 3 splines it doesn’t.]
5. Isocurve analysis on both rails and centreline lofts seems to be not working properly. Depending on the type and shape of the guidelines, some or all of the U or V curvature combs are missing as applying different number of isocurves [Not shown: in this particular design, only when choosing the straight lines (not the splines) of Sketch3 as rails on both sides, the curvatures combs (U and V) are shown properly regardless the number of isocurves]
6. Using symmetric rails or choosing a centreline, don’t understand why curvature combs of the isocurves are not symmetric on a fully symmetric solid as the one in this case. [Not shown: It is more clear at certain number of isocurves]
Hope it is clear and not wasting anyone's time
