Loft Issue
Loft Issue
snoofydog
Message 1 of 8
Loft Issue
snoofydog
Is this not possible with loft?
Closed sketch, 2 separate sketches on separate planes
Chose the closed sketch as profile and the 2 other sketches as rails
Ok button greyed out. Is it because the profile sketch is closed?
Replies (7)
Message 2 of 8
jeff_strater
Yes, and no.  You can do a loft similar to this with a couple of restrictions:
  1. it has to be a surface loft (at least I was unable to get it to work with a solid loft)
  2. you have to make sure the closed loop in the base is really two different curves
  3. you have to turn off chain select
Here is a screencast:
Jeff
Jeff Strater
Engineering Director
Message 3 of 8
snoofydog
Thanks Jeff,
How do I make the first sketch. 2 open profiles.
When I draw two separate splines they want to always become 1.
Is there a split node command?
Message 4 of 8
snoofydog
Managed to split the node with unfix?
Don't know if that is correct?
But still can't make it work
File attached
Message 5 of 8
TheCADWhisperer
See attached.
Message 6 of 8
jeff_strater
Most likely you forgot to turn off chaining in the Loft command.  Your curve is correctly split, you should be able to loft it.
Jeff
Jeff Strater
Message 7 of 8
snoofydog
Thanks Jeff and Cad Whisperer
Could you post a screen cast of you you did it in a model.
I select the first sketch in tsplines or model and even I cannot isolate one side of the sketch.
I still don't fully understand how to break apart a sketch
I would really like to do this in t splines loft, but again, either side of the first sketch cannot be selected.
Message 8 of 8
jeff_strater
Again, make sure that you have de-selected "Chain Selection" in the loft dialog.  This is what allows you to select just one curve for a profile.  Also, you need to manually add a new profile for the other curve, to guarantee that the curves are not automatically joined together into one profile:
Jeff
Jeff Strater
