I have a problem with creating a loft (the post https://forums.autodesk.com/t5/design-validate-document/loft-problem-with-rails-surely-already-asked...)
But I have a more general question :
can a rail be made of
- a line for the the 3 first profiles
- a spline for the 4th p
- another spline for the profiles 5 to 8,
- another spline for profiles 9 to 10 ....
and so on. This rail is of course continuous, and even differentiable (all lines are tangent to the next curve).
Because, despite that I accuretaly constructed the intersection with rail1 and2 with every profile, my loft stops at the 4th profile (the transition between the line and the spline).
To be very precise, the rail 2 is a projection on a surface of a plane sketch, gathering a line, a spline, a line, an arc of circle, a line and a spline.
The surface is ruled (an extrude), done with a single spline.
Tx for your infos.
