Compatability Issue After Latest Update
oldtbone55
Message 1 of 13
oldtbone55
After the latest update I could no longer open Fusion 360 on my laptop. I did some troubleshooting under the compatability testing and it seems that my laptop is incompatable with the latest update. Is there anything specific in the update that would cause this? I know my graphics card is the best for Fusion 360 environment but I wasn't having any trouble prior to the update. Can anyone comment on this?
Thanks.
Replies (12)
Message 2 of 13
Beyondforce
Hi @oldtbone55,
I'm guessing you are on a MAC. If that's the case, you should update your IOS version to the latest one! Please read this:
https://forums.autodesk.com/t5/design-validate-document/mac-os-x-10-9-users-please-read/td-p/6581863
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 13
oldtbone55
Thanks for your reply Ben but I'm on a Microsoft platform. Not sure if my
graphics card is the issue but it was working before the update..
Message 4 of 13
Beyondforce
How did you do the "compatibility testing"?
Ben Korez
| YouTube
Message 5 of 13
oldtbone55
I used the troubleshooting software that's part of the Microsoft platform.
It compared the requirements of Fusion against my laptop operating system
and hardware. The software notified me that there might be a hardware
compatability isuue which is why I ran the troubleshooting software. I've
deleted Fusion from my laptop and may try to re-install it again to see if
what happens.
Message 6 of 13
Beyondforce
If you still have problems, then try to update or re-install the graphic driver.
Ben Korez
| YouTube
Message 7 of 13
innovatenate
Autodesk Support
Autodesk Support
@oldtbone55 What exactly is happening when you start Fusion 360? I didn't see any error reports submitted by your e-mail address. Are you sending reports to Autodesk (if they are prompting you to do so)? It will look something like the below screenshot.
If you're not getting one of these, there's a good chance that it is graphics related. Updating your display driver from the Intel, AMD, or NVidia website would be good thing to do.
I hope that helps!
Nathan Chandler
Principal Specialist
Message 8 of 13
oldtbone55
Thanks, I already checked the graphic drivers and they are latest
available. I'm a little surprised that Fusion isn't working based on the
system requirements listed for it. These may not be the optimal
requirements however and only the minimal.
Message 9 of 13
oldtbone55
I'm not getting any error reports when I try to open Fusion. Nothing
happens whatsoever. I've checked my graphics drivers to determine if I had
the latest versions and I do. Based on the system requirements noted I
shouldn't really be having this problem although I know that my graphics
card isn't optimal for Fusion. The system requirements may be the minimal
required but system performance may not be very good.
Message 10 of 13
innovatenate
Autodesk Support
Autodesk Support
Can you send me the dxdiag report?
1. Run dxdiag.exe on your system (you can search for this on your computer in the start menu)
2. Select Save All TXT
3. Then upload the results text file here?
It is also possible that there is interference from a 3rd party application like anti-virus software. If this is the case, it may help to add some exceptions to the settings in your anti-virus software. I am happy to help make suggestions here if you let me know what brand/version of anti-virus software you're running.
Nathan Chandler
Message 11 of 13
oldtbone55
I'll have to re-load Fusion onto my laptop before I can run the diagnostic
software. As soon as I do I'll run dxdiag and send you the results.
Thanks very kindly for your help.
Message 12 of 13
innovatenate
Autodesk Support
Autodesk Support
Just so you know, dxdiag.exe is a tool associated with the Windows Operating system. You can run this diagnostic program without having to install Fusion 360.
Nathan Chandler
Message 13 of 13
oldtbone55
System Information
Time of this report: 12/19/2016, 20:08:32
Machine name: JOANNEPC
Machine Id: {6AC702A9-B304-4CD4-9DAA-35AE022F2FC1}
Operating System: Windows 10 Home 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.161208-2252)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire V5-571P
BIOS: V2.03
Processor: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz (4 CPUs), ~1.8GHz
Memory: 8192MB RAM
Available OS Memory: 7988MB RAM
Page File: 3134MB used, 6132MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_072D1025&REV_09
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 1792 MB
Dedicated Memory: 96 MB
Shared Memory: 1696 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO31EC
Native Mode: 1366 x 768(p) (60.098Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll
Driver File Version: 10.18.0010.4358 (English)
Driver Version: 10.18.10.4358
DDI Version: 11.2
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 2015-12-20 7:00:00 PM, 11157656 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-4226-11CF-9362-2727B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x072D1025
Revision ID: 0x0009
Driver Strong Name: oem34.inf:5f63e5341859ec8c:iIVBM_w10:10.18.10.4358:pci\ven_8086&dev_0166
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_1025072D&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6690 (English)
WHQL Logo'd: Yes
Date and Size: 2012-07-24 12:00:00 AM, 4097808 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 7/31/2012 12:48:12, 4097808 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 1
FriendlyName: HD WebCam
SymbolicLink: \\?\usb#vid_064e&pid_e330&mi_00#7&23164d0f&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Manufacturer: Microsoft
HardwareID: USB\VID_064E&PID_E330&REV_0100&MI_00,USB\VID_064E&PID_E330&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.14393.82
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 2006-06-21 12:00:00 AM
Service: usbvideo
Class: Image
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: HD WebCam
Parent: USB\VID_064E&PID_E330\6&28927842&0&4
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: n/a
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: Imaging
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Radio Controller
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1025, 0x0759
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Touchscreen
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04F3, 0x0023
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC52E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (xHCI)
| Vendor/Product ID: 0x8086, 0x1E31
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 7/16/2016 06:41:55, 535904 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 7/16/2016 06:41:55, 169312 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 9/18/2016 12:56:14, 38400 bytes
| | | Driver: hidclass.sys, 10/14/2016 22:55:50, 156672 bytes
| | | Driver: hidparse.sys, 9/18/2016 12:56:14, 40960 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 9/15/2016 11:43:23, 39424 bytes
| | | | Driver: kbdclass.sys, 7/16/2016 06:41:54, 62304 bytes
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/16/2016 06:41:54, 32256 bytes
| | | | Driver: mouclass.sys, 7/16/2016 06:41:54, 59232 bytes
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x1025, 0x0000
| Service: kbdhid
| Service: kbdhid
+ ELAN Input Device
| Matching Device ID: acpi\etd0504
| Upper Filters: ETD
| Service: i8042prt
| Driver: ETD.sys, 10/7/2015 02:11:38, 525512 bytes
| Driver: ETDCtrl.exe, 10/7/2015 02:11:38, 3242696 bytes
| Driver: ETDUninst.dll, 10/7/2015 02:11:40, 2238152 bytes
| Driver: ETDUn_inst.exe, 10/7/2015 02:11:40, 2451144 bytes
| Driver: ETDDeviceInformation.exe, 10/7/2015 02:11:38, 2790088 bytes
| Driver: ETD_DLL.dll, 10/7/2015 02:11:40, 2549448 bytes
| Driver: ETDService.exe, 10/7/2015 02:11:38, 144072 bytes
| Driver: ETDCtrlHelper.exe, 10/7/2015 02:11:38, 2580168 bytes
| Driver: ETDApix.dll, 10/7/2015 02:11:38, 2641608 bytes
| Driver: ETDCmds.dll, 10/7/2015 02:11:38, 2755784 bytes
| Driver: ETDMcpl.dll, 10/7/2015 02:11:40, 5241032 bytes
| Driver: ETDAniConf.exe, 10/7/2015 02:11:38, 8405192 bytes
| Driver: ETDSetup.ini, 9/25/2015 04:09:02, 439676 bytes
| Driver: ETDFavorite.dll, 10/7/2015 02:11:38, 2591432 bytes
| Driver: i8042prt.sys, 7/16/2016 06:41:54, 114176 bytes
| Driver: ETDCoInstaller01000.dll, 10/7/2015 02:11:38, 56008 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 575.6 GB
Total Space: 700.8 GB
File System: NTFS
Model: WDC WD7500BPVT-22HXZT3
Drive: 😧
Model: HL-DT-ST DVDRAM
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:53, 173056 bytes
System Devices
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_072D1025&REV_C4\3&11583659&0&E0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.14393.0479 (English), 11/11/2016 05:00:00, 335712 bytes
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_072D1025&REV_04\3&11583659&0&B0
Driver: C:\WINDOWS\system32\DRIVERS\HECIx64.sys, 8.01.0000.1263 (English), 7/2/2012 17:16:02, 62784 bytes
Name: Intel(R) 7 Series Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1E03&SUBSYS_072D1025&REV_04\3&11583659&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStorA.sys, 11.05.0000.1207 (English), 7/9/2012 15:43:12, 645952 bytes
Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_072D1025&REV_04\3&11583659&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.14393.0000 (English), 7/16/2016 06:41:55, 381792 bytes
Name: Intel(R) HD Graphics 4000
Device ID: PCI\VEN_8086&DEV_0166&SUBSYS_072D1025&REV_09\3&11583659&0&10
Driver: C:\WINDOWS\system32\DRIVERS\igdkmd64.sys, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 3811288 bytes
Driver: C:\WINDOWS\system32\igd10iumd64.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 12442464 bytes
Driver: C:\WINDOWS\system32\igdusc64.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 4702968 bytes
Driver: C:\WINDOWS\system32\igdmd64.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 480592 bytes
Driver: C:\WINDOWS\system32\igfxcmrt64.dll, 3.00.0000.1284 (English), 5/3/2016 22:31:28, 209648 bytes
Driver: C:\WINDOWS\system32\igfx11cmrt64.dll, 3.00.0000.1284 (English), 5/3/2016 22:30:46, 202248 bytes
Driver: C:\WINDOWS\system32\igfxcmjit64.dll, 3.00.0000.1284 (English), 5/3/2016 22:30:46, 2044424 bytes
Driver: C:\WINDOWS\system32\IccLibDll_x64.dll, 5/3/2016 22:30:46, 111624 bytes
Driver: C:\WINDOWS\system32\igdde64.dll, 5/3/2016 22:30:46, 238600 bytes
Driver: C:\WINDOWS\SysWow64\igdde32.dll, 5/3/2016 22:30:46, 200200 bytes
Driver: C:\WINDOWS\system32\iglhxs64.vp, 12/30/2015 22:52:52, 2582 bytes
Driver: C:\WINDOWS\system32\iglhxo64.vp, 12/30/2015 22:52:52, 44025 bytes
Driver: C:\WINDOWS\system32\iglhxc64.vp, 12/30/2015 22:52:52, 43494 bytes
Driver: C:\WINDOWS\system32\iglhxg64.vp, 12/30/2015 22:52:52, 43256 bytes
Driver: C:\WINDOWS\system32\iglhxo64_dev.vp, 12/30/2015 22:52:52, 42079 bytes
Driver: C:\WINDOWS\system32\iglhxc64_dev.vp, 12/30/2015 22:52:52, 43816 bytes
Driver: C:\WINDOWS\system32\iglhxg64_dev.vp, 12/30/2015 22:52:52, 43298 bytes
Driver: C:\WINDOWS\system32\iglhxa64.vp, 12/30/2015 22:52:52, 1125 bytes
Driver: C:\WINDOWS\system32\iglhxa64.cpa, 12/30/2015 22:52:52, 2813952 bytes
Driver: C:\WINDOWS\system32\iglhcp64.dll, 9.00.0020.9000 (English), 5/3/2016 22:31:28, 240432 bytes
Driver: C:\WINDOWS\system32\iglhsip64.dll, 9.00.0020.9000 (English), 5/3/2016 22:31:28, 1174832 bytes
Driver: C:\WINDOWS\SysWow64\igdusc32.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 3726232 bytes
Driver: C:\WINDOWS\SysWow64\igdmd32.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 390928 bytes
Driver: C:\WINDOWS\SysWow64\igd10iumd32.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:28, 12007936 bytes
Driver: C:\WINDOWS\SysWow64\igdumdim32.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:30, 10675896 bytes
Driver: C:\WINDOWS\SysWow64\igdail32.dll, 5/3/2016 22:30:44, 161288 bytes
Driver: C:\WINDOWS\SysWow64\iglhcp32.dll, 9.00.0020.9000 (English), 5/3/2016 22:31:28, 204840 bytes
Driver: C:\WINDOWS\SysWow64\iglhsip32.dll, 9.00.0020.9000 (English), 5/3/2016 22:31:28, 1170640 bytes
Driver: C:\WINDOWS\SysWow64\IntelCpHeciSvc.exe, 9.00.0020.9000 (English), 5/3/2016 22:30:46, 299488 bytes
Driver: C:\WINDOWS\SysWow64\igfxcmrt32.dll, 3.00.0000.1284 (English), 5/3/2016 22:31:28, 179600 bytes
Driver: C:\WINDOWS\SysWow64\igfx11cmrt32.dll, 3.00.0000.1284 (English), 5/3/2016 22:30:46, 172552 bytes
Driver: C:\WINDOWS\SysWow64\igfxcmjit32.dll, 3.00.0000.1284 (English), 5/3/2016 22:30:46, 1775624 bytes
Driver: C:\WINDOWS\system32\difx64.exe, 1.04.0003.0000 (English), 5/3/2016 22:30:44, 175072 bytes
Driver: C:\WINDOWS\system32\igfxDH.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 690696 bytes
Driver: C:\WINDOWS\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 77320 bytes
Driver: C:\WINDOWS\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 87048 bytes
Driver: C:\WINDOWS\system32\igfxDI.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 302088 bytes
Driver: C:\WINDOWS\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 28168 bytes
Driver: C:\WINDOWS\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 28168 bytes
Driver: C:\WINDOWS\system32\igfxLHM.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 269832 bytes
Driver: C:\WINDOWS\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 22536 bytes
Driver: C:\WINDOWS\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 22536 bytes
Driver: C:\WINDOWS\system32\igfxEM.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 549344 bytes
Driver: C:\WINDOWS\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 27656 bytes
Driver: C:\WINDOWS\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 5/3/2016 22:30:46, 27656 bytes
Driver: C:\WINDOWS\system32\GfxUIEx.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:44, 978400 bytes
Driver: C:\WINDOWS\system32\Gfxv4_0.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 4401632 bytes
Driver: C:\WINDOWS\system32\Gfxv4_0.exe.config, 12/30/2015 22:52:36, 889 bytes
Driver: C:\WINDOWS\system32\Gfxv2_0.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 4398048 bytes
Driver: C:\WINDOWS\system32\Gfxv2_0.exe.config, 12/30/2015 22:52:36, 895 bytes
Driver: C:\WINDOWS\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 5/3/2016 22:30:46, 626696 bytes
Driver: C:\WINDOWS\system32\igfxCUIServicePS.dll, 5/3/2016 22:30:46, 103944 bytes
Driver: C:\WINDOWS\system32\igfxCUIService.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 337888 bytes
Driver: C:\WINDOWS\system32\igfxCPL.cpl, 5/3/2016 22:30:46, 272904 bytes
Driver: C:\WINDOWS\system32\igfxTray.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 391648 bytes
Driver: C:\WINDOWS\system32\igfxDTCM.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 226824 bytes
Driver: C:\WINDOWS\system32\igfxHK.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 266208 bytes
Driver: C:\WINDOWS\system32\igfxOSP.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 388616 bytes
Driver: C:\WINDOWS\system32\DPTopologyApp.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 564696 bytes
Driver: C:\WINDOWS\system32\DPTopologyApp.exe.config, 12/30/2015 22:52:34, 889 bytes
Driver: C:\WINDOWS\system32\CustomModeApp.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 418784 bytes
Driver: C:\WINDOWS\system32\CustomModeApp.exe.config, 12/30/2015 22:52:34, 889 bytes
Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 564192 bytes
Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe.config, 12/30/2015 22:52:34, 895 bytes
Driver: C:\WINDOWS\system32\CustomModeAppv2_0.exe, 8.15.0010.4358 (English), 5/3/2016 22:30:44, 418264 bytes
Driver: C:\WINDOWS\system32\CustomModeAppv2_0.exe.config, 12/30/2015 22:52:34, 895 bytes
Driver: C:\WINDOWS\system32\igfxext.exe, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 213984 bytes
Driver: C:\WINDOWS\system32\igfxexps.dll, 6.15.0010.4358 (English), 5/3/2016 22:31:28, 49936 bytes
Driver: C:\WINDOWS\SysWow64\igfxexps32.dll, 6.15.0010.4358 (English), 5/3/2016 22:30:46, 48136 bytes
Driver: C:\WINDOWS\system32\resARA.cui, 12/30/2015 22:53:10, 164932 bytes
Driver: C:\WINDOWS\system32\resCHS.cui, 12/30/2015 22:53:10, 149060 bytes
Driver: C:\WINDOWS\system32\resCHT.cui, 12/30/2015 22:53:10, 149924 bytes
Driver: C:\WINDOWS\system32\resCSY.cui, 12/30/2015 22:53:10, 156132 bytes
Driver: C:\WINDOWS\system32\resDAN.cui, 12/30/2015 22:53:10, 153028 bytes
Driver: C:\WINDOWS\system32\resDEU.cui, 12/30/2015 22:53:10, 157892 bytes
Driver: C:\WINDOWS\system32\resELL.cui, 12/30/2015 22:53:10, 183476 bytes
Driver: C:\WINDOWS\system32\resENU.cui, 12/30/2015 22:53:10, 151684 bytes
Driver: C:\WINDOWS\system32\resESN.cui, 12/30/2015 22:53:10, 157572 bytes
Driver: C:\WINDOWS\system32\resFIN.cui, 12/30/2015 22:53:10, 155460 bytes
Driver: C:\WINDOWS\system32\resFRA.cui, 12/30/2015 22:53:10, 159716 bytes
Driver: C:\WINDOWS\system32\resHEB.cui, 12/30/2015 22:53:10, 164356 bytes
Driver: C:\WINDOWS\system32\resHRV.cui, 12/30/2015 22:53:10, 155060 bytes
Driver: C:\WINDOWS\system32\resHUN.cui, 12/30/2015 22:53:10, 159732 bytes
Driver: C:\WINDOWS\system32\resITA.cui, 12/30/2015 22:53:10, 157860 bytes
Driver: C:\WINDOWS\system32\resJPN.cui, 12/30/2015 22:53:10, 164404 bytes
Driver: C:\WINDOWS\system32\resKOR.cui, 12/30/2015 22:53:10, 158004 bytes
Driver: C:\WINDOWS\system32\resNLD.cui, 12/30/2015 22:53:10, 156836 bytes
Driver: C:\WINDOWS\system32\resNOR.cui, 12/30/2015 22:53:10, 153508 bytes
Driver: C:\WINDOWS\system32\resPLK.cui, 12/30/2015 22:53:10, 157140 bytes
Driver: C:\WINDOWS\system32\resPTB.cui, 12/30/2015 22:53:10, 156228 bytes
Driver: C:\WINDOWS\system32\resPTG.cui, 12/30/2015 22:53:10, 155940 bytes
Driver: C:\WINDOWS\system32\resROM.cui, 12/30/2015 22:53:10, 157668 bytes
Driver: C:\WINDOWS\system32\resRUS.cui, 12/30/2015 22:53:10, 179252 bytes
Driver: C:\WINDOWS\system32\resSKY.cui, 12/30/2015 22:53:10, 157012 bytes
Driver: C:\WINDOWS\system32\resSLV.cui, 12/30/2015 22:53:10, 154484 bytes
Driver: C:\WINDOWS\system32\resSVE.cui, 12/30/2015 22:53:10, 154628 bytes
Driver: C:\WINDOWS\system32\resTHA.cui, 12/30/2015 22:53:10, 190868 bytes
Driver: C:\WINDOWS\system32\resTRK.cui, 12/30/2015 22:53:10, 156116 bytes
Driver: C:\WINDOWS\system32\ig7icd64.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 8531456 bytes
Driver: C:\WINDOWS\SysWow64\ig7icd32.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 6518792 bytes
Driver: C:\WINDOWS\system32\igdumdim64.dll, 10.18.0010.4358 (English), 5/3/2016 22:31:30, 11157656 bytes
Driver: C:\WINDOWS\system32\igdail64.dll, 5/3/2016 22:30:44, 179720 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 12/30/2015 22:53:04, 1981 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 12/30/2015 22:53:06, 9788 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 12/30/2015 22:53:06, 32 bytes
Driver: C:\WINDOWS\SysWow64\Intel_OpenCL_ICD32.dll, 1.02.0011.0000 (English), 5/3/2016 22:30:46, 77832 bytes
Driver: C:\WINDOWS\SysWow64\IntelOpenCL32.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 304136 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 225288 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 6776328 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 644104 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 326152 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 12/30/2015 22:53:04, 2986764 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 12/30/2015 22:53:04, 240244 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 12/30/2015 22:53:04, 375380 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 12/30/2015 22:53:02, 2930216 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 12/30/2015 22:53:02, 234396 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 12/30/2015 22:53:02, 374552 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 12/30/2015 22:53:04, 2408580 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 12/30/2015 22:53:04, 197272 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 12/30/2015 22:53:04, 329372 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 14906888 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 5911560 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 5182472 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 4695048 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.00.2012.0408 (), 5/3/2016 22:30:48, 183240 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.00.2012.0408 (), 5/3/2016 22:30:48, 350664 bytes
Driver: C:\WINDOWS\system32\Intel_OpenCL_ICD64.dll, 1.02.0011.0000 (English), 5/3/2016 22:30:46, 81416 bytes
Driver: C:\WINDOWS\system32\IntelOpenCL64.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 394248 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 263688 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 9179144 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 814088 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 390152 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 12/30/2015 22:53:02, 2941464 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 12/30/2015 22:53:02, 295744 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 12/30/2015 22:53:02, 388464 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 12/30/2015 22:53:02, 2884992 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 12/30/2015 22:53:02, 284840 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 12/30/2015 22:53:02, 387724 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 12/30/2015 22:53:02, 2365892 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 12/30/2015 22:53:02, 228328 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 12/30/2015 22:53:02, 342372 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 3.00.0001.10891 (English), 5/3/2016 22:30:48, 19593736 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 6108168 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 5529608 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 2.00.0000.0000 (English), 5/3/2016 22:30:48, 5076488 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.00.2012.0408 (), 5/3/2016 22:30:48, 215496 bytes
Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.00.2012.0408 (), 5/3/2016 22:30:48, 425928 bytes
Driver: C:\WINDOWS\SysWow64\igdbcl32.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:44, 338952 bytes
Driver: C:\WINDOWS\SysWow64\igdrcl32.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 1803784 bytes
Driver: C:\WINDOWS\SysWow64\igdfcl32.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:48, 17854984 bytes
Driver: C:\WINDOWS\system32\igdbcl64.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 383496 bytes
Driver: C:\WINDOWS\system32\igdrcl64.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 2004488 bytes
Driver: C:\WINDOWS\system32\igdfcl64.dll, 10.18.0010.4358 (English), 5/3/2016 22:30:46, 22922760 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 5.15.0005.0029 (English), 5/3/2016 22:30:48, 8401664 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 3.11.0005.0020 (English), 5/3/2016 22:30:46, 599296 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 6.15.0006.0002 (English), 5/3/2016 22:30:46, 820920 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 6.15.0006.0002 (English), 5/3/2016 22:30:46, 763576 bytes
Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 12/30/2015 22:52:36, 28553 bytes
Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 12/30/2015 22:52:34, 846855 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 12/30/2015 22:52:34, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 12/30/2015 22:52:34, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 12/30/2015 22:52:58, 26945 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 5.15.0005.0029 (English), 5/3/2016 22:30:48, 9309440 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 3.11.0005.0020 (English), 5/3/2016 22:30:46, 696064 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 6.15.0006.0002 (English), 5/3/2016 22:30:46, 1013432 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 6.15.0006.0002 (English), 5/3/2016 22:30:46, 942776 bytes
Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 12/30/2015 22:52:36, 6533 bytes
Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 12/30/2015 22:52:34, 1519616 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 12/30/2015 22:52:34, 993 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 12/30/2015 22:52:34, 21523 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 12/30/2015 22:52:58, 6321 bytes
Driver: C:\WINDOWS\system32\IntelWiDiMCUMD64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 150504 bytes
Driver: C:\WINDOWS\system32\IntelWiDiSecureSourceFilter64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 1478632 bytes
Driver: C:\WINDOWS\system32\IntelWiDiAAC64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 4033000 bytes
Driver: C:\WINDOWS\system32\IntelWiDiMux64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 625640 bytes
Driver: C:\WINDOWS\system32\IntelWiDiDDEAgent64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 199656 bytes
Driver: C:\WINDOWS\system32\IntelWiDiAudioFilter64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 668136 bytes
Driver: C:\WINDOWS\system32\IntelWiDiUtils64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 232424 bytes
Driver: C:\WINDOWS\system32\IntelWiDiLogServer64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 116200 bytes
Driver: C:\WINDOWS\system32\IntelWiDiWinNextAgent64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 881128 bytes
Driver: C:\WINDOWS\system32\IntelWiDiSilenceFilter64.dll, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 366560 bytes
Driver: C:\WINDOWS\system32\IntelWiDiVAD64.exe, 4.05.0072.0000 (English), 5/3/2016 22:30:48, 2516360 bytes
Driver: C:\WINDOWS\system32\IntelWiDiUMS64.exe, 4.05.0072.0000 (English), 5/3/2016 22:30:46, 452576 bytes
Driver: C:\WINDOWS\system32\igfxCoIn_v4358.dll, 1.03.0012.0000 (English), 5/3/2016 22:30:46, 206856 bytes
Driver: C:\WINDOWS\system32\DisplayAudiox64.cab, 12/30/2015 22:52:34, 316245 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_072D1025&REV_04\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:52, 83456 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:52, 97280 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:52, 366592 bytes
Device ID: PCI\VEN_8086&DEV_1E16&SUBSYS_072D1025&REV_C4\3&11583659&0&E3
Name: Realtek PCIE CardReader
Device ID: PCI\VEN_10EC&DEV_5289&SUBSYS_528910EC&REV_01\4&259FD6F&0&00E2
Driver: C:\WINDOWS\system32\DRIVERS\RtsBaStor.sys, 6.01.8400.27023 (English), 6/13/2012 21:23:58, 294544 bytes
Driver: C:\WINDOWS\SysWOW64\RtsBaStorIcon.dll, 1.00.0008.0000 (English), 6/13/2012 21:23:58, 9888912 bytes
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_072D1025&REV_04\3&11583659&0&E8
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:55, 96096 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:55, 455520 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:55, 501088 bytes
Device ID: PCI\VEN_8086&DEV_1E14&SUBSYS_072D1025&REV_C4\3&11583659&0&E2
Name: LPC Controller
Device ID: PCI\VEN_8086&DEV_1E57&SUBSYS_072D1025&REV_04\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.14393.0000 (English), 7/16/2016 06:41:53, 18784 bytes
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_072D1025&REV_04\3&11583659&0&D0
Name: Qualcomm Atheros AR5BWB222 Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_0034&SUBSYS_662111AD&REV_01\4&11F15DCF&0&00E3
Driver: C:\WINDOWS\system32\DRIVERS\athw8x.sys, 10.00.0000.0225 (English), 1/21/2013 01:56:12, 3747840 bytes
Name: Memory Controller
Device ID: PCI\VEN_8086&DEV_0154&SUBSYS_072D1025&REV_09\3&11583659&0&00
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_012310EC&REV_0A\4&259FD6F&0&02E2
Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0404.2015 (English), 7/16/2016 06:41:53, 589824 bytes
Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_072D1025&REV_04\3&11583659&0&FB
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.14393.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.14393.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.14393.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.14393.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.14393.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.14393.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.14393.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.14393.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.14393.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.14393.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.14393.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.14393.0000
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.14393.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.14393.0000
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.14393.0206
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.14393.0479
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.14393.0206
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.14393.0000
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.14393.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.14393.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.14393.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.14393.0206
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.14393.0000
DV Splitter,0x00600000,1,2,qdv.dll,10.00.14393.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.14393.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.14393.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.14393.0000
Video Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.14393.0206
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.14393.0000
Video Renderer,0x00400000,1,0,quartz.dll,10.00.14393.0000
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.14393.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.14393.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.14393.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.14393.0000
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.14393.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.14393.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.14393.0206
Null Renderer,0x00200000,1,0,qedit.dll,10.00.14393.0206
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.14393.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.14393.0206
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.14393.0206
Smart Tee,0x00200000,1,2,qcap.dll,10.00.14393.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.14393.0000
Wave Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.14393.0000
File stream renderer,0x00400000,1,1,quartz.dll,10.00.14393.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.14393.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.14393.0206
AVI Mux,0x00200000,1,0,qcap.dll,10.00.14393.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.14393.0000
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.14393.0000
File Source (URL),0x00400000,0,1,quartz.dll,10.00.14393.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.14393.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.14393.0187
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.14393.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.14393.0000
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.14393.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.14393.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.14393.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.14393.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.14393.0000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.14393.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.14393.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0000
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0000
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.14393.0000
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.14393.0000
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.14393.0000
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.14393.0000
Audio Capture Sources:
Microphone (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.14393.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.14393.0351
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.14393.0000
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.14393.0000
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
HD WebCam,0x00200000,1,2,ksproxy.ax,10.00.14393.0000
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.14393.0000
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.14393.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.14393.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.14393.0351
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.14393.0351
PTFilter,0x00200000,0,0,EncDec.dll,10.00.14393.0351
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.14393.0351
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.14393.0000
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.14393.0000
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.14393.0000
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.14393.0000
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
Video Decoders:
Intel? Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 6.15.0006.0002
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.14393.0479
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.14393.0000
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.14393.0479
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.14393.0000
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.14393.0479
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.14393.0000
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.14393.0000
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.14393.0000
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.14393.0000
Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.14393.0000
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.14393.0000
Video Encoders:
Intel? Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 6.15.0006.0002
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.14393.0000
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.14393.0000
Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.14393.0206
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.14393.0000
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.14393.0000
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.14393.0000
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.14393.0000
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.14393.0000
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.14393.0206
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.14393.0000
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.14393.0351
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.14393.0351
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.14393.0000
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.14393.0000
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.14393.0479
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.14393.0479
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.14393.0000
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.14393.0000
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.14393.0000
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.14393.0000
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.14393.0479
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.14393.0479
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.14393.0000
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.14393.0000
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.14393.0479
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.14393.0479
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.14393.0000
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.14393.0000
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.14393.0000
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.14393.0000
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.14393.0000
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.14393.0000
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.14393.0000
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.14393.0206
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.14393.0000
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.14393.0000
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.14393.0206
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.14393.0479
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
, , [, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
, , [, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
{00001600-0000-0100-0800-000aa00389b71}, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: PCA2
Response: Not available
Cab Id: 0
Problem signature:
P1: FusionLauncher.exe
P2: 2390.2.1.0
P3: unknown
P4: Neutron
P5: Autodesk, Inc.
P6: 100
P7: 0
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 127695178030, type 5
Event Name: MpTelemetry
Cab Id: 0
Problem signature:
P1: Windows Defender (77BDAF73-B396-481F-9042-AD358843EC24)
P2: 4.10.14393.0
P3: TimeOut
P4: 1.1.13303.0
P5: fixed
P6: 4 / 2049+
P7: 8 / not boot
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 127695178015, type 5
Cab Id: 0
Problem signature:
P2: 4.10.14393.0
P3: TimeOut
P4: 1.1.13303.0
P5: fixed
P6: 4 / 2049+
P7: 5 / not boot
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P2: 4.10.14393.0
P3: TimeOut
P4: 1.1.13303.0
P5: fixed
P6: 4 / 2049+
P7: 8 / not boot
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P2: 4.10.14393.0
P3: TimeOut
P4: 1.1.13303.0
P5: fixed
P6: 4 / 2049+
P7: 5 / not boot
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket 133376795753, type 5
Event Name: MoAppHang
Cab Id: 0
Problem signature:
P1: Microsoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbwe
P2: praid:MicrosoftEdge
P3: 11.0.14393.82
P4: 57a55786
P5: 27b8
P6: 133120
P7:
P8:
P9:
P10:
+++ WER6 +++:
Fault bucket 129163447618, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: TiWorker.exe
P2: 10.0.14393.0
P3: 10.0.14393.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Fault bucket 133377588380, type 5
Cab Id: 0
Problem signature:
P3: 11.0.14393.82
P4: 57a55786
P5: 6cf2
P6: 133120
P7:
P8:
P9:
P10:
+++ WER8 +++:
Fault bucket 133379542667, type 5
Cab Id: 0
Problem signature:
P3: 11.0.14393.82
P4: 57a55786
P5: 5d94
P6: 133120
P7:
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket 133378596994, type 5
Cab Id: 0
Problem signature:
P3: 11.0.14393.82
P4: 57a55786
P5: 5559
P6: 133120
P7:
P8:
P9:
P10:
