loft failure: modified cylinder to modified square
jbpoole7777
jbpoole7777
I am trying to loft a truncated cylinder TO a filleted square.  Failed.  Tried rails still failed.  Pic attached. Advice?
jhackney1972
You will need to attach your Fusion 360 model.  If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.
John Hackney, Retired
davebYYPCU
No blue shaded profiles for a solid Loft
No orange icons for surface Loft.
Might help....
jeff_strater
I assume you want a "hollow loft" here.  The Fusion modeling kernel does not support hollow loft (I know, I know, it doesn't seem reasonable, but that is just the inherent limitation of the algorithm).  You'll have to do this in two lofts - one for the entire outer boundary, and a cut loft to subtract the inner body.
Jeff Strater
Engineering Director
jbpoole7777
f3d file attached.  I understand from another response that I must loft then cut loft to get a hollow loft.  I can not get the standard loft to work.  Any advice is appreciated.  Thanks for your time.
g-andresen
Watch the screencast and follow the timeline.
günther
jbpoole7777
THANK YOU VERY MUCH, GUENTHER!!!!
