Loft Error - Tangent and Self Intersection
I have a propeller with multiple cross sections (profiles). I'm attempting to loft between the x-sections.
Because it is a vintage scimitar shape I'm using two rails (spline) to shape along the length of the prop. 5 of 6 loft sections work as expected. I don't understand why the middle section does not. Rail one works in both cases, adding the second rail generates the error.
1) If the spline/rail #2 is full length of the prop I get "rails cannot be tangent to profile" just for the one section
2) If the spline/rail #2 is only drawn between the two cross sections I get "Loft would intersect itself". This one does not make sense to me, the two sections are parallel faces.
The two cross sections and rails are successfully used to create the loft sections before after the problem one. What are the errors really trying to tel me is wrong.
