Loft ending angle
Loft ending angle
calexpavel
Message 1 of 8
Loft ending angle
calexpavel
So i am creating this loft but at the top it turns/rotates too much and i need to cap it. Is there any way to control that angle?
File: http://a360.co/2DJc5BB
Replies (7)
Message 2 of 8
jeff_strater
@calexpavel,
You can control this by switching the condition at the ending profile from "Connected" to "Direction", and then you can adjust the "takeoff weight":
Just curious about why you are doing this loft in the Sculpt environment.  The Model or Patch loft is a lot more accurate, if you want to closely match the profiles.  A Sculpt loft is perfectly valid, but just wanted to make through you were doing this intentionally.
screencast:
Jeff Strater
Engineering Director
Message 3 of 8
laughingcreek
2 ways come to mind
1-connect the profiles with a spline rail
2- add an extra profile, and cut the tspline back after the loft
Message 4 of 8
calexpavel
Thanks Jeff! I tried your solution but i hoped there's a better way, since doing that makes a small bulge and i want a straight line. I am doing this in t-splines because i want to further edit the shape of it and t-splines seems more flexible when working with organic shapes.bulge.jpg
Message 5 of 8
calexpavel
Hmm...your second way seems good. Loft with rail i tried but i can't make it look good. I need to keep practicing loft with rails.
Cheers!
Message 6 of 8
calexpavel
@jeff_strater
Hey Jeff,
Could i loft the object in the model context and then import it in the sculpt context and further edit it there?
Message 7 of 8
jeff_strater
Yes and no.  You can create the loft in Model/Patch, then create a new Form feature, and from within the Sculpt workspace, you can use Convert to convert a single face to a Sculpt body.  It is limited to one face, though.  In your case, you can do this, but it is not true in all cases.   However, as a glimpse under the hood, this is how the Sculpt Loft command works internally, so the results will be the same, so it doesn't really help you much.
Jeff Strater
Message 8 of 8
calexpavel
I see. It's good to know. Thanks!
