Loft dosen't work
Loft dosen't work
nystrom.nils
Loft dosen't work
nystrom.nils
Hi Fusion 360 community!
Im trying to loft these two empty spaces but it dosent work properly. Does anyone have any ide how to loft or any other way just to make the surface flat (+thicken) so i can work the piece in cam?
Best regards, Nils
sunil.patilQCZZK
Hi @nystrom.nils ,
I can see those faces are non planar faces. As I understood your final agenda is to close the empty faces. One of the approach is to try selecting the thickness and deleting them which will close the portion you highlighted. Please find the screencast showing the procedure and fixed file for your reference.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! "Like" is always welcomed.
Sunil Patil,
Technical support specialist Fusion360,
Autodesk, Inc.
nystrom.nils
That will do! Thank you so much!
TrippyLighting
I would start over from scratch!
Make sure that all your sketches are properly constrained and dimensioned.
