loft curve
loft curve
jedandva12
Message 1 of 12
loft curve
jedandva12
Hi guys, i have an loft question. I'm trying to replicate this curve on the photo.
I have to use a loft function to complete my shape.
What I've tried using two rectangles let's say they are 100x20mm. On the second rectangle I use a 3d sketch to make a curve, but then my sketch isn't recognized as a face.
Can someone share their own opinion on how they would  draw this ?
Replies (11)
Message 2 of 12
g-andresen
Please show pictures with complementary hand sketches of what you want to end up with and share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 3 of 12
jedandva12
Loft sketch 1-2
try to recreate the slight bend on right like shown on real life item on picture
Message 4 of 12
g-andresen
Please show pictures from other perspectives.
günther
Message 5 of 12
jedandva12
I need this curve, I have to use profiles because I want lofted shape. My shape won't be square like in real life.
As you can see it's hollow. I will use profile sketches and loft function to get the shape, then i will shell it. But I  dont know how to create the curve.
-Forget about the tapered shape.
-I cant cut the shape from a block, because I need the lofted shape that will transition into a pipe at the end. Lofted shape- so fluid flows nicely.
Message 6 of 12
g-andresen
Please show the whole part from different angles.
günther
Message 7 of 12
jedandva12
Message 8 of 12
g-andresen
maybe you can do something with it
günther
Message 9 of 12
TrippyLighting
Preferably with the keep tangent edges option enabled (loft dialogue)!!!
Message 10 of 12
g-andresen
I know!
günther
Message 11 of 12
jedandva12
I did play with loft setting curvature and tangent,  i get the clearance, it ends up rounded. but I cant replicate this factory curve. Now  I've cutted the part in two, have to figure out how to make some kind of click clack joint. I plan to 3d print it in 2 parts.
My first part failed the geometry was a bit to aggressive.
Message 12 of 12
TrippyLighting
It is unclear who you are replying to. Please do not use the reply at the very bottom of the thread, but reply to a specific post.
