Hi everyone,
This is my first project on Fusion although I have gone through tutorials and think I have a good understanding of the basics by now. It would be great if the following could be cleared up:
For the joint between the armrest, the back leg and the connection between the two armrests, I used loft. This however does not give me a smooth transition. I used Loft in other areas as well so I wonder if for this problem, I better use an other command?
And if i want to smooth out other areas of the model, is it best to convert to T-Splines ? ( modifying the same joinery after converting it does not go well)
Another issue is that when i want to shorten the back leg, the armrest goes down as well. I've tried removing constraints but this remains a problem where i can only redo the spline that makes the armrest.
A more general question, and hopefully also appropriate to ask here: Looking at the design history, did I make mistakes/create potential issues in the future. Parts of this chair need to be CNC'd so I need to get this model ready for that process as well.
Thanks in advance,
Ruben
