Loft between 2 circles on xz and yz planes using rails
davidbeckettL87UZ
davidbeckettL87UZ
Hi
I am trying to loft between 2 circles one on xz and one on yz planes using rails. I get an error saying the selected rail does not touch all the profiles. My rail sketch is on the xy plane and when editing this sketch the other 2 sketches are greyed out so I cannot project the circles on to my rail sketch to join the rail sketch to the circles. Any help greatly apreciated!
Dave
TheCADWhisperer
White dots.  Not good.
Blue lines. Not good.
laughingcreek
a few thoughts-
-attaching your model conveys more information for those helping.  at least show the timeline and the browser if you can't do that (you can export a .f3d file from the "file" menu and attach to post)
-are you using project intersect on the circles?
-this loft might be better as a center line loft instead of using multiple rails (the "center line" doesn't have to be in the center, it could still be one of your rails.
-probably be even better to use a sweep instead of a loft.
davidbeckettL87UZ
Hi really appreciate the help, attached .f3d file.
TheCADWhisperer
See Attached.
TheCADWhisperer
@davidbeckettL87UZ
I should point out that this is not how I would really do the part - I was simply pointing out the issues that you missed.
g-andresen
Here is a screenshot showing the missing contact of the rails
günther
