Linking two joints to rotate via a connecting rod / axle
michaelhmail
michaelhmail
Hi
Hoping someone can help me work out what I am missing. I'm tryng ( and have been trying for a few days ) to build a joint motion that links the two L shaped parts below so that if I move one of the L parts the other one also moves.
So effectivelly
the L shape parts are connected to the rod  / axle
the rod rotates when I move one of the L parts
which in turn rotates the other part.
Thank you
davebYYPCU
Not checked the file yet,
what is grounded?
Both move at same rate 1:1 motion?
Are the 2 L plates joined by an axle, move one the other goes?
Might help….
michaelhmail
At the moment I have grounded the axle.
Yep the two L plates joined by an axle and 1:1 motion.
jhackney1972
You did not say if you wanted them synchronized, to each other, in a certain position, it can be changed. Model attached.   If you need help, let me know.
Edit: Second model attached with L-Shaped Components lined up and moving together.
John Hackney, Retired
jhackney1972
Does my post solve your issue?  Need more help?  If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
michaelhmail
Thank you so much - perfect
