I sound like a broken record, stuck again
gpetti20
Message 1 of 8
gpetti20
Trying to do a monogram for my family. got somewhat thru it. cant get my sketch to fully define. I have tried the line trick and fill gaps addon but not much luck. See attached . advise when you can.
Thanks, Glenn
Replies (7)
Message 2 of 8
TheCADWhisperer
@gpetti20
Something like this doesn't have to be fully defined.
But find the gaps and lots of white dots (missing Coincident Constraints in some locations).
In the process of diagnosis I notice zero length line(s) (now not zero length after click and drag in image...)
Message 3 of 8
gpetti20
Find the gaps meaning broken lines ??
Glenn
Message 4 of 8
gpetti20
If I could keep Fusion from freezing up every 5 minutes I could search closer in. I don't know why this happens so often to me. It might be me overloading the program or I don't have something setup right
Message 5 of 8
TheCADWhisperer
If this were my design...
1. I would start out using obvious symmetry about the Origin.
2. I would do this as at least 4 separate sketches rather than as one massive sketch.
3. I would not have any duplication (mirror) of sketch entities.
4. I would not have any white dots.
5. I would not have any zero length lines.
Message 6 of 8
gpetti20
Got it. Thank you for your guidance and help with this.
Glenn
Message 7 of 8
TheCADWhisperer
@gpetti20
Was all of this geometry imported or was some of it created natively?
I suspect that my short answer in previous response will need elaboration to fully understand.
Keep sketches simple.
Several simple(r) sketches rather than a single complex sketch.
Mirror (duplicate) Bodies or Features rather than sketch elements.
Message 8 of 8
gpetti20
Yes it was imported as a DXF file from esty.
Glenn
