Note that I understand everything is a component in Fusion but I'm calling things assemblies and parts in this post just to distinguish between a component which as an assembly, and components which are just parts within it, otherwise I will drive myself mad trying to write this. Also note that I have followed rule #1 before replying about that.
I have created project A with a multi levelled test assembly to get a feel for how Fusion works with linked documents, with several parts and a sub-assy in each, and have got on okay so far with that.
Now I created another project B to see how Fusion works with reusing some existing assys and parts from project A in a different project, and.... I just cannot figure out how to do this.
After struggling with this for a while I read that you can't do this in your single user storage, so I created a team for myself, and then moved my projects there.
I still can't see a way to add components from project A straight into project B, so I then made an empty assembly in Project B and browsed in the data panel to one of the assys in project A, and right clicked 'insert into current design'. I get a warning 'Designs inserted from another Hub will not be linked' which only gives me the option to copy it over, which I don't want to do as I want to retain the link to the original so I don't have duplicates of the same parts. I also don't know what a 'Hub' is. Is that the same as the team?
When I view the other project in the data panel I can't seem to find a way to see or access the contents of an assembly, ie where a component contains multiple parts. Can you only insert an entire assembly from another project unless you model every part as separate top level components?
Peter
