Linking Dimensions between projects
quentinl3000
Observer Observer
quentinl3000
Observer
Observer
I have a design I am working on with multiple parts that I have split up into separate documents. Is it possible to drive the dimensions of one part from another in a different file.
Basically i just need to be able to inherit parameters from one file to another. Is there any way that this can be done?
lichtzeichenanlage
You can't do this.
etfrench
What you can do is export parameters from one file and import them into another with this Add-In.
ETFrench
quentinl3000
Observer
Observer
if i change the parameters in one will it change them in the other
etfrench
No, you'll need to do the export/import each time you change a parameter.  It is less than ideal, but it's better than editing each file manually.
ETFrench
