Linked component not showing while rendering
Is there any way to fix it as all the linked component and parts shows in render environment,however after doing final render all the linked component vanishes . it only happens in this particular assembly .
pic 2 is while in render environment
pic 2 is after final render .
lucasliraAU
Hi @Anonymous
Thanks for reaching out to us on the forums!
I have been following these accounts for some time here in the community posted by users.
This type of problem is caused by the use of cloud rendering. I do not have a definition about this type of occurrence.
My recommendation for an immediate solution is that you can run renderings on your own workstation and an alternative I've been recommending to users who are experiencing this type of problem.
Here are some links that can direct you to other users who have faced the same type of problem.
forums.autodesk.com/t5/fusion-360-design-validate/render-moving-parts/m-p/7953378#M156705
https://forums.autodesk.com/t5/fusion-360-support/rendering-failure/m-p/8076102#M29281
https://forums.autodesk.com/t5/fusion-360-support/june-11-2018-cloud-rendering/td-p/8068761
If you have some kind of problem with your local rendering, you can provide me with your project file that will be available to run this rendering job.
Hope this helps you in your activities!
Greetings!
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
