Link Modeling 2d Drawing
sjahnGL3GH
sjahnGL3GH
Hello
There is a drawing called A that has completed modeling and drawing work.
It's all the same as A while working on another project and only the hole location and size are different.
I modified A's modeling and saved it under a different name B.
So they had to redraw the drawing of B.
Download the drawing to f3z, upload it to another project folder, model it, modify the drawing and save it under a different name, so the link between the modeling and the drawing is broken, so it is impossible to modify the drawing cannot be modified.
Previously used NX saves modeling A as another name, B.
I've got all the modeling and drawing information.
After modification of the modeling, the drawings are linked to each other, without any additional drawing work.
I used it by touching up the drawing.
How can I use it in FUSION360?
jhackney1972
Two drawings of different models should never be linked.  This would lead to all sorts of errors and confusion.
John Hackney, Retired
