Link leads to no access
First Name: Phill
Last Name: Murray
Email Address: phillmurray@live.ca
I am going thru the training material for Fusion 360 Autodesk Fusion
360: Introduction, page 9.
Get Started: To get started with Fusion
360, we will log in, create a project, and save a design to the
project. Step 1 – Download files 1. Click the link below to
access the zipped dataset. If clicking the link does not work, you can
copy and paste the link into a browser.
https://myhub.autodesk360.com/ue29c9141/shar
es/public/SH7f1edQT22b515c761e12e3a50ab9cda 319 2. Click to start
the download. 3. When the download is complete, unzip the files.
Make note of where you put the files. You will use these throughout
the training. Launch Video.
And then I get this. I am logged in
to A360 and Fusion360. "Unauthorized Sorry. You don't have
permission to access this page." I would like to get these files and
start. Thanks from Phill.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
This link must be old! In the past, we had users download the sample files - but in a recent build of Fusion, these are now included in your data panel by default. There is no need anymore to download then reupload these samples. To find these sample files:
  • Open Fusion 360
  • Expand your Data Panel and go to the Project List
  • Scroll down to the Bottom
  • Depending on the tutorial you are following (most are in our learning content here - each section has a Hands On section which references the samples), you will need to access different Sample Projects. You are most likely looking for the ones in Basic Training. Please note that the first few files in here are intentionally blank.
Let me know if you need any help.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thanks so much James. And there they were!
First class help and kudos to you.
svnuckova
Hallo Phil, can you please provide me the link that had that incorrent info about tutorial datasets? It would be helphul to see the page that needs to be updated.
Thank you,
Stepa Vnuckova
Link from 360 training pdf is https://myhub.autodesk360.com/ue29c9141/shares/public/SH7f1edQT22b515c761e12e3a50ab9cda 319 2.
Your action will lessen frustration of others. Thanks.
My problem in the training materials is first post in this thread and James Youmatz response is the fix.
