Link component between projects
mika.takalo
Message 1 of 21
mika.takalo
Hey.
I want to use same components in many projects. When I insert a component in an assembly from different project, fusion makes a copy from that component. This is definitely not that what I want to happen. So, how to make links between projects?
Replies (20)
Message 21 of 21
mika.takalo
Good to hear that possibility is coming. Hopefully those same components can be used in a different projects, because I do not want to make copies. I'll design one component just a one time and give a drawing number for it. That item number is used in a multiple projects. There should be also a possibility to replace component with another component in an assembly. It is just not good way to delete hundred "bolts" and bring another size hundred "bolts" back to assembly with new joints. It just takes too much time, too much work.
