can a sketch line be linked that has had the link broken?
(in the code it can be done, because repair projections lets you link any existing projected line to anything).
one use case is when you redefine the sketch plane and everything gets "break linked" and "fixed".
also, being able to link the existing line retains the downstream features (extrude profiles, etc)
off topic, I create 2 additional sketches now, to protect my complex sketches.
sketch i) project other part geometry
sketch ii) project sketch i)
sketch 1) project sketch ii) and add offset clearances etc
so when sketch i breaks, I can delete it and project again.
then sketch ii i can re-link without offset curves going haywire
and sketch 1 never knew anything was broken 🙂
已解决! 转到解答。
