- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm designing a stepper motor mount, and am wondering if there's a simple way to get the mounting holes on the motor to line up with the mounting plate.
In this image, I need to put four 5mm holes in the plate under the motor for mounting. In something like SketchUp, I'd probably put vertical guides through the center of each hole and create corresponding circles on the top of the plate.
I considered copying the holes from the motor model, but I can't get them to copy / paste into a different sketch.
I'm very new to Fusion - any help would be appreciated. I have quite a few components that need to be mounted in this way. The plates are going to be CNC'd after I get all the holes placed so it's pretty important that they are accurately positioned.
