Lines on top of lines
yoshimitsuspeed
Advisor Advisor
Message 1 of 13
yoshimitsuspeed
In sketch if you have a shorter line on top of a longer line and you go to select or dimension the shorter line it should be easier to select. It always defaults to the longer line making it impossible to select or dimension the shorter line without moving it. It is possible to dimension the shorter line using it's end points but it should be possible to select the shorther line.
https://www.facebook.com/groups/1229995573786339/
Replies (12)
Message 2 of 13
Pedro_Bidarra
You can select overlapping entities by holding the mouse left button and then releasing it, it then presents you a list of entites that are on top of each other for you to select, this allows you browse through them and select.
Message 3 of 13
GRSnyder
This is one area where Fusion 360 doesn't really improve on Inventor, and neither solution is really very good. There's got to be a clever way to make this task easier.
Message 4 of 13
TimeraAutodesk
Message 5 of 13
jenschrDRCX6
This no longer seems to work for me in 2019. I only get the normal popup menu, so it is impossible for me to select the correct line. Did this change with more recent versions?
As indicated by @yoshimitsuspeed this is a really bad behavior and it saddens me to see that the problem has been around for 4 years without being solved. If you hover over 2 lines, selecting the shorter one is the obvious thing to do. The other one you can always select a different place in the drawing.
Message 6 of 13
g-andresen
You should try again.
I have been using one of the two methods shown for more than three years.
left click+hold >dimensionleft click+hold >dimension
günther
Message 7 of 13
jenschrDRCX6
You are completely right günther!
I tried this with no result, but I guess I'm not patient enough? I expected the dialogue to show right away, but it takes almost a second it seems. Works when I click and HOLD for some time without releasing. Thanks!
Message 8 of 13
chrisplyler
Yeah, the, "Click and release," instruction was deceptive. It's more accurate to say, "Click and hold until selection menu pops up."
Message 9 of 13
Thanks for posting these tips,
I get the one by one selection / delete method,
Was wondering, struggling to find google :-
is there a tool, menu option or method, to Select all sketch lines and merge?
Keywords:
Flatten sketch
Join Sketches
Merge Lines
Merge all
Bounce tracks "Same thing within the audio world "DAW" to mix all tracks together..
Select Merge all
copy to one object sketch
copy to new sketch as one drawing
Make sketch whole
Join all connected lines
Join overlapped lines
Make sketch complete
Thin combine drawing
Remove duplicate lines
Combine duplicate lines
Make sketch layers single layer
Combine Sketch Layers
Check for Overlap's
Select all overlap's
Remove overlapping lines
select nested sketch lines
Flatten to DXF
Make Waterjet / Laser Sketch
NUKE all unneeded lines💥
Please help , by the way i'm working in latest Mac Fusion 360
Message 10 of 13
chrisplyler
Um...nope. Sorry.
Message 11 of 13
MoshiurRashid
A line on a line is the overlapping line. overlapping entities can be selected individually by holding the mouse left button on it and releasing it, then the list of entites will appear. select any one of them you want to work with and do it.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 12 of 13
TrippyLighting
@MoshiurRashid This is an ancient thread and so are some others that you have responded to. Before you are posting, perhaps it's not a bad idea to ask yourself what you would be adding to the conversation. For example, repeating advise already given twice in a thread isn't adding anything of value 😉
Message 13 of 13
jenschrDRCX6
Pssst: it was @Anonymous  re-opening the thread and yes - it's a recurring problem 😉
